993 Forum 1995-1998
Trackday setup
Old Sep 9, 2010 | 06:55 PM
Jack Ennuste's Avatar
Jack Ennuste
Default Trackday setup
I think that this topic is discussed here many times. But anyways, what is the best wheel alignment setup purely for track? I have 225/40 R18 in front and 285/30 in back.
Old Sep 9, 2010 | 07:21 PM
jdistefa's Avatar
jdistefa
235 in the front would be better for a start
close to 0 toe front
max front camber (if no adjustable upper camber plates)
max front caster (max is often asymmetrical, pair to lesser side unless you're racing oval )
square rear camber (equal to the front, up to -2 deg)
kinematic 2-4, within 1 symmetrical
Old Sep 10, 2010 | 01:11 PM
Jack Ennuste
Thank's Matt
So, basically -2 degree camber, 0 degree toe in every corner.
How much does kinematic affect on the track in reality?
Jaak
Old Sep 10, 2010 | 01:57 PM
jdistefa's Avatar
jdistefa
Jack,
Yikes, no, you still need some rear toe, suggest RS spec if you have rubber bushings, less than RS spec if you have spherical bearings in the rear control arms.
Remember that kinematic is essentially dynamic toe (and a bit of dynamic camber) so in short, yeah, it's important .
Old Sep 11, 2010 | 04:49 AM
rw229's Avatar
rw229
Running -1.9 camber front with 1/32 toe and 5.4 caster. -2.5 camber rear with 3/32 toe. Very neutral, slight understeer. Sorry, no kimematic spec.
Old Sep 11, 2010 | 08:07 AM
Bill Verburg's Avatar
Bill Verburg
I agree w/ JD after running several different setups
front
camber -2.4*
toe 0
castor maxed I could only get ~4.5*
rear
camber -2
toe in .22*
ride height 24.5/24.75" full RS spec suspension(don't go there w/ out it)
I like more camber in front for better turn in, i'm using 225/265
I like 285 rears but don't like the tall 235s from Michelin, I would want 245/35 front w/ 285/30 rear
Old Sep 11, 2010 | 08:38 PM
Jack Ennuste
Thanks for practical advice!
Jack
