TPC charge cooler question
Question for the 993 owners with the full TPC supercharger and chargecooler install.
When all tuned does your car suffer from hunting idle on cold start, slow response from the Idle stabilisation valve, engine stalling when on full lock at around idle.
I currently have a charge cooler which is NOT mfr by TPC which is giving me the above issues. With cooler removed it all goes away and i have a higher boost pressure but with the same 2psi drop off above 4k.
The reason for the question is i believe my current Charge cooler is restricting air flow and am now looking into buying the TPC charge cooler which would hopefully be more free flowing, but don't want to end up with the same issue, so some real life experience would be great.
