Top part of my hifi speaker enclosure is coming off... PIC
after checking http://p-car.com/diy/ard/
I looked and all of the door panel screws are there and these clips i assume should slide into a slot and should not have this adhesive on them correct? I guess the PO decided to glue them. Anyway, can you buy these little clips or and i going to have to reglue them back? I would rather just have the non hifi panels and not deal with this. is this normal?
Isn't this the 993 you just picked up?
I remember reading your thread about you deciding whether or not you should buy it...
I wish I had an answer...but I don't. Possibly take back to dealer and have them repair?
yes.. my new to me 993. its not that big of a deal and the car is "as is" so they arent going to fix it. Im just curious if I can buy the clips or if it was glued in OEM
If I recall correctly from the last time I had mine off, it is a blade and slot fitting, with no retention at that point. The door panel is held in place by the screws along the bottom edge.
I would check those screws to see if they might have been stripped out, causing someone to try a relatively sloppy repair with the glue.
Take the speaker cover off. All you need is a phillips screw driver. Clean the glue off. The panels are a little fussy in that they must be fitted tight before inserting the screws or they will will have a little gap in the spot you took a picture of. Once apart it will become clear how it should fit together. I think the PO did not realize this and decided to glue it back. I have had to adjust the covers after a speaker swap but after a couple of try's fit correctly again.
