95 G50 serial numbers help ...please
Having trouble finding this info. perhaps a member knows the answer, I'd like to know the serial numbers of the early 95 g50 that had only 1st gear on the main shaft , I understand later 95 and anything newer had 1st and 2nd on main shaft anyone have the serial numbers for the early ones? Thanks in advance guys....
All of the /20 & /21 can have 3-6 changed easily enough, 1 & sometimes 2 are integral w/ the main shaft, the changeover trans #s are
G50.20 - 02693
G50.20 - 02174 (M220)
G50.21 - 05072
G50.21 - 03094 (M220)
before only 1 is fixed after 1 & 2 are fixed, to change them a new mainshaft is required(last price I saw Was ~$2000, I'me sure it's much more now)
The Motorsports boxes, /30 -/33 have loose gears in all positions 1-6
Many choose to leave the main shaft alone and change 3-6 and that works but isn'e really an optimal way to do it.
G50.20 - 02693
G50.21 - 05072
The way I read this info .The box you have located is one built after the change so 1st and 2nd are fixed to the main shaft. Newer than 2693 without LSD (220) or 2174 with LSD. were the last ones with a loose first. My 95 was built in 12/94 and has a gearbox with LSD that falls just after the change (number around 2200) .
