993 Forum 1995-1998
Spark plug wire replacement?
Old 08-19-2010, 01:29 PM
Slow Guy
Slow Guy's Avatar
I suspect mileage has only a small impact on the need for wire replacement, age would have a bigger impact along with the climate the car is driven. Just a guess but I bet in a hot/dry climate they would have a shorter lifespan. Just my .02
Old 08-19-2010, 01:42 PM
mike cap
mike cap's Avatar
Matt,
My plug wires are like new at 37,000 miles. But the car has always been in the cooler NE climate and not subjected to rain, snow or salt. I would be certain that your plug wires are fine. Any 'cracking' you may see is the cosmoline that Porsche sprayed everywhere underneath the car and oversprayed on the plug wires.
Old 08-19-2010, 01:52 PM
chris walrod
Guru
Rennlist Small
Business Sponsor
chris walrod's Avatar
The most frequent killer of wires is oil and particularly the lowers. When (not if) your lower v/c's leak, typically oil soaks into and degrades the wire insulation. Many times we've seen lower wires that have fallen-apart.
So, fix those v/c cover leaks!!
Old 08-19-2010, 07:39 PM
e9stibi
e9stibi's Avatar
I can confirm this from recent experience. I would just inspect them and change as required.
Old 08-19-2010, 07:43 PM
cgfen
cgfen's Avatar
Originally Posted by Matt Lane
I am coming up on 38K miles, and and preparing for my second "30K mile" service. Did the first one when I bought the car at 16K miles. Car runs great, no cels, wondering if it makes sense to change the plug wires pre-emptively now. Or wait. Big $$...
Looking for your experiences:
1. At what mileage did you change your plug wires?
2. Were they causing problems, or was it preventative maintenance?
3. Did you notice a big difference? How did the old wires and connectors look?
Will be interesting to see the collective input!
Best,
Matt
28K
#3 exhaust wire was rotted with chunks of insulation falling off.
no performance difference noted
i reused the connectors at both ends, all wires except #3 exhaust looked great.
I'd consider this a do it if you have to thing, not just to have a good time scraping your knuckles
good luck
Craig
Old 06-03-2013, 04:28 AM
mani993
mani993's Avatar
Default air intake
ok
Old 06-03-2013, 04:54 AM
kjr914
kjr914's Avatar
Originally Posted by mani993
If anyone knows what or where they sell just the porsche ends and boots let me know.
The first site points you to the 2nd...
http://kingsborne.com/
http://www.beruparts.com/
In addition to the above, for wires, there are a couple of individuals that have made sets, if you are looking to save money/resuse boots, only for a few wires or a bit of engine bay bling/color:
Mark Robinson
Alex (IXLR8)
Old 06-03-2013, 09:11 AM
jg291446
jg291446's Avatar
On my side I don't know about the mileage but maybe it was the original. At Lear, they had not been changed since 8 years and they wore in a really bad shape. The wire were cracked and there was sparkles everywhere. The car was not running that bad, but know I see a big difference.
Old 06-03-2013, 09:40 AM
TJ993
TJ993's Avatar
Anyone have an accurate sketch of The Usual Suspects - the usual Failing wires?
I had # 6 Replaced at 88,000.
If I read here correctly # 5 is next??
Now my car has 122,857 Miles.
Perhaps it is time to change all of the wires? Thoughts?
My car on damp days sound like an Old Chevy. Suggestions welcomed.
I love how people post here sayin this is easy and it takes an hour - well sometimes true, but I am not overly mechanical and I find yah its an hour job if your mechanically inclined and you have done the job twice before...just my observation
Old 06-03-2013, 12:12 PM
Kika
Kika's Avatar
I changed all of mine around 90k. The lowers on 5 and 6 looked the worst. I perhaps could have gotten by with reusing the connectors and doing the wires only, but I got a good deal on a set from a rennlister that converted his car to coils.
The likelihood that all 12 are bad is small, but on the other hand, do you want to chase down each one as they go bad? Personally, I opted to change all of them, realizing that I was probably changing 10 of them that were good.
Old 06-03-2013, 03:48 PM
Ocean Blue C2S
Ocean Blue C2S's Avatar
FYI
I just got a quote from a Porsche dealership in a tax-free state for the cost of Spark Plug wires, they said that it was not sold as a set but sold as individual wires at $ 77.58 each, so $ 930,96 to have those replaced. I thought that it was sold as a set as advertised by Pelican.
The Coil Wires, as quoted by this tax-free state dealership were $ 37.89 each, thus $ 75.78 for two, plus whatever cost, like shipping and for me it would be more cost to bring them into Canada.
What did Vertex charge TargaGR??????????
Cheers,
Bert
Old 06-04-2013, 08:26 AM
TJ993
TJ993's Avatar
Hi KiKA;
My thoughts exactly. Why do 1 since u r in there anyway!
So I went down to the local dealer and asked the same question. The pricing here is Phenominal. Actual by dealer price we r talkin like $700. plus 13% Taxes CDN for complete set of wires = $800. then add cost of install.OUCH !
Parts fellow seems like a good guy, thankfully, but said this:
We usually do not do plug wire replacements till after 150,000 so we only do one at a time. Guess that makes sense.
But considering price I am being quoted in T.O> (slang for Toronto) and what is being charged here for Labour - Based on service providers existing in a seasonal driving climate I figured I might just want to give this a try as a DIY.
Found a set on ebay for $418. That helps.
Still like to try the ohms test on the wires themselves, no idea how?? Ideas ?
Friend of mune says its likely a coil gone bad.
What is a realistic DIY Time for full replacement?
Anyone know of deals on full set or isa this good?
Thanks Tom
Old 06-04-2013, 11:51 AM
cgfen
cgfen's Avatar
Originally Posted by Stealth 993
I did mine @ my 90kmi service, it was a BIG waste of time & $$.
My thought is if you are not having arcing problems, or misfires, leave them alone.
Agreed.
If you are not having any issues and you don't see any physical damage, leave them be.
I changed mine @ ~ 25K only because one of the wire's insulation was visibly damaged (# 3 exhaust.)
WHOOPS old thread..
Old 06-04-2013, 03:10 PM
trophy
trophy's Avatar
Mine are being changes with my engine rebuild. Once I took them apart and cleaned the I found a number of cracked wires and a cracked sparkplug boot end. my car has 62k on it, lots of track work so heat could be the culprit.
Old 06-04-2013, 04:08 PM
PelicanParts.com
Basic Sponsor
PelicanParts.com's Avatar
We offer complete sets as well as DIY kits for the 993. If DIYing a complete set, the process is not difficult and shouldn't take longer than a few hours:
Ignition Plug Wire Sets
Mark/Pelican Parts
Your Trusted Source For DIY and Parts
FREE SHIPPING over $99 click here
Porsche Parts | DIY Tech Articles | Facebook | Twitter | Instagram | YouTube | Promos
888.280.7799 | 6am - 5pm PST
Quick Reply: Spark plug wire replacement?
