Euro GT3 seat install - sliders?
I think I have the right BK side mounts and related belt and sub hardware ready to go, just misssing the right sliders.
For those that have installed the Euro GT3 seats in the 993, what are the correct Recaro sliders to order? Part numbers?
Thanks in advance - looking to order right the first time!
Best,
Matt
Best,
Matt
Managed to find a prior post recommending:
Recaro Sliders 0.70.9NT ("No Tabs")
Is this correct?
And, any recommendations on best place to order, price and service?
Best,
Matt
Is this correct?
Best,
Matt
Mounting the seats is pretty easy Matt. Do you have all hardware to "re-install" the female seatbelt receiver? I'm assuming you are installing a extinguisher mount in front of the passenger seat too. If so, you'll need a few extra washers to shim up the rear of the side mount to slider connection to the thickness of the extinguisher mount.
I think I have the parts required, based on recommendation from Bob Brooks and eStibi.
BK side mounts, sub bars, and belt attachment loops (extenders). Just need sliders for now... I think
The truth will be known once it's all test fitted.
Extinguisher will be mounted to the roll bar.
Best,
Matt
Best,
Matt
Matt - you are ok with "my" part list. Just be prepared to Dremel some holes in the sliders to make them fit.
Good Luck. It should not be too difficult IF YOU HAVE THE RIGHT COMPOENENTS.
