Ultimate LWF Clutch parts thread
Did a quick search for (recent) threads on parts needed for a LWF and clutch replacement. I hope to do the engine drop and clutch replacement as soon as the temps drop a little around here (may be a couple of months though
So unless someone can point me to an existing thread maybe we can use this for a parts list. I may end up copying/pasting all parts suggested into a single posting to make it easier for people searching for this info later.
Would like to break this into 3 sections, parts you need to do the job, parts you should replace and those nice to do while the engine is dropped parts.
Thanks in advance.
Necessary Parts
- Lightweight flywheel RS (LFW)
- RS Flywheel starter ring gear
- RS Clutch (does this come in a "kit"?
- Pressure plate
- Throwout bearing
- Pres. Plate bolts
- Flywheel bolts
- RS Guide Tube
- Pilot Bearing
Should replace now
- clutch slave cyl. hose (even if slave isn't replaced)
- clutch slave cyl.
- Rear main seal
- Valve cover gaskets
- SAI Valve (clean ports?)
Nice to do now
- short shift kit
- replace motor/tranny mounts
- Plug wires
Thanks in advance.
Necessary Parts
- Pressure plate
- Throwout bearing
- Pres. Plate bolts
- Flywheel bolts
- RS Guide Tube
- Pilot Bearing
Should replace now
- clutch slave cyl.
- Rear main seal
Nice to do now
- short shift kit
- Plug wires
Whole lot of info there but here's a quick breakdown...
Complete Clutch Kit - 993 116 911 01 Sachs OEM Replacement includes Clutch Disc, Pressure Plate and Release Bearing - $814.50
Release Bearing Seperate - 950 116 080 08 Sachs OEM Replacement $163.47
Slave Cylinder - 950 116 237 12 FTE OE Replacement $123.19
Motor Mount Right - 965 375 050 00
Motor Mount Left - 965 375 049 00
Trans Mount (Excluding RS America) - 964 375 055 02
Trans Mount RS America - 965 375 055 80
Dual Mass Flywheel - 964 114 012 99
Carrera RS Clubsport Flywheel - 964 102 239 31
Thats a start.. there's quite a few different possible combinations. I have everything in stock if anyone needs a kit!
This might help. It's in a nicer format on the DIY.
Neil
RS LWF 964 102 239 31 445.89
RS PP 964 116 028 53 418.52
RS disc 996 116 015 32 349.85
RS starter ring gear 964 114 143 31 145.02
RS guide tube 950 116 813 30 79.04
Rear main seal 999 113 426 41 21.53
Flywheel bolts 928 102 151 01 22.86
PP bolts n 014 715 3 2.88
Release bearing 944 116 080 01 141.65
Pilot bearing 931 102 111 00 20.36
Clutch Fork 950 116 086 06 156.95
Needle Bearing 999 201 365 00 3.54
Needle Bearing 999 201 339 00 4.30
Bearing Seals 999 113 418 40 1.50
Clutch Shaft 950 116 725 00 38.39
Neil
This is a great mod. I am sure there are many good sources via RL, but I have to put in a good word for Darin and Mark at FDM. Great prices on all the parts, but more importantly, great support when installing the parts (ask me how I know
) Here is a link....FD Motorsports
Seared
If still original, the rubber clutch slave supply hose should be replaced as well.
Andreas
