Feeler: price for 18" narrow body hollow spokes
Would like to hear opinions on a fair price for an OEM set of 18" hollow spokes (turbo twists) in narrow-body fitment in excellent condition - straight, true, and no curb rash whatsoever. I know they are (semi) rarish, but not really "unobtainium".
fronts:
- 18" x 8"
- ET 52 (mm)
- p/n: 993.362.136.00
rears:
- 18" x 10"
- ET 65 (mm)
- p/n: 993.362.140.01
TIA
fronts:
- 18" x 8"
- ET 52 (mm)
rears:
- 18" x 10"
- ET 65 (mm)
TIA
Why do I feel so left out!
Calling CACTUS!!!!
fronts:
- 18" x 8"
- ET 52 (mm)
rears:
- 18" x 10"
- ET 65 (mm)
TIA
fronts:
- 18" x 8"
- ET 52 (mm)
rears:
- 18" x 10"
- ET 65 (mm)
TIA
You need to be aware that your 8" wide front wheels were originally made for the widebody cars and are much rarer and valuable in a NB set than the 7.5" wide version, which is what came on NB cars from the factory (ET 56 mm, p/n 9993.362.134.05). You don't see this combination of widths in a package for NB very often, usually you would have to buy the 8" wheels in a set of 4 for widebody and split the set, sell off the rears, etc. which would be an expensive exercise all by itself. The premium here would probably be $200 to $300 over a set with 7.5" fronts.
Could be wrong, but the 7.5" width wheel is a 993 part number and the sets I've seen for sale with 8" fronts have been widebody offsets for rears. May be it's an early ('95/'96) wheel offering. At anyrate, finding 8" fronts alone or in a NB set doesn't happen very often as far as I've seen.
My '96 NB 993 also came from the factory with 8" front hollow spokes, PN 993.362.136.00 (ET52), and 10" rears, PN 993.362.140.01 (ET65) so the same as the OP is asking about. They were part of the "sport chassis with 18" wheels" option package which ran $3901.
Great info, thanks.
I will have to double-check the part numbers (I am currently out of town) but I am reasonably sure that the fronts are 18"x8".
For now, I will probably keep the wheels, but thank you for the inquiries I have received. It wasn't my intent to get anyones hopes up.
Info I've mined from previous posts in a couple of formats:
Hollow Spoke “Technology” wheels:
993.362.136.00 – 18x8 ET52 - 19.95 lb (front)
993.362.140.01 – 18x10 ET65 - 23.36 lb (narrow body rear)
993.362.140.00 – 18x10 ET40 - 25.13 lb (wide body rear)
993.362.134.05 – 18x7.5 ET50 - 18.95 (front) 996
Solid Spoke Turbolook wheels:
993.362.136.01 - 18x8 ET52 - 25.57 lb (front)
993.362.140.04 - 18x10 ET65 - 29.32 lb (narrow body rear)
993.362.140.03 - 18x10 ET40 - 31.08 lb (wide body rear)
The solid spoke wheels are as follows:
Description Part No Dia Width Offset Weight
Turbo 1 – solid spoke 993.362.134.06 18 7.5 50 11.3 kg
Turbo 1 – solid spoke 993.362.136.01 18 8 52 11.6 kg
Turbo 1 – solid spoke 993.362.138.01 18 9 52 13.2 kg
Turbo 1 – solid spoke 993.362.140.03 18 10 40 14.1 kg
Turbo 1 – solid spoke 993.362.140.04 18 10 65 13.3 kg
The hollow spokes are:
Turbo 1 – hollow spoke 993.362.134.05 18 7.5 50 8.6 kg
Turbo 1 – hollow spoke 993.362.136.00 18 8 52 8.9 kg
Turbo 1 – hollow spoke 993.362.138.00 18 9 52 10.2 kg
Turbo 1 – hollow spoke 993.362.140.00 18 10 40 11.4 kg
Turbo 1 – hollow spoke 993.362.140.01 18 10 65 10.6 kg
Preferred tyre sizes for the 7.5J & 9J are 225/40 and 265/35.
valve stems 993 361 073 00
A yeomans work, to be sure, and thank you for that.
Alternatively you could look at http://www.944racing.de and click on "Felgen" on the left-hand-side and then on "Tabelle" in the ensuing text. HTH
