993 Forum 1995-1998
Gizmo help
Old Jul 20, 2010 | 12:03 AM
JPS's Avatar
JPS
Default Gizmo help
Looking for sort of a mini comealong. Duh...on the cab DAS rollbar, if I pulled the uprights on the seat belt attach points in the rear inward a bit, it would slide in and out in probably half the time and quit ripping my carpet. But a comealong seems huge for what I need. Thoughts?
Old Jul 20, 2010 | 01:06 AM
stace's Avatar
stace
some steel cable with a small turnbuckle? you can make small adjustments and it is compact. just an idea.
Old Jul 20, 2010 | 04:11 AM
CalvinC4S's Avatar
CalvinC4S
a ratchet strap is what you need.
http://www.youtube.com/watch?v=1kE4xnA-eEY
Old Jul 20, 2010 | 04:46 PM
JPS's Avatar
JPS
THx. Seems reasonable.
Old Jul 20, 2010 | 05:03 PM
bart1's Avatar
bart1
I have a super beefy ratchet strap you could come over and use, but NY is pretty far from AL.
I am assuming your tweaking will be done with the bar in situ?
edit: I have a longer, yellower, version of this. 4 of them will lift a HMMWV (according to my military friend).
http://store.colemans.com/cart/ratch...l?currency=USD
Old Jul 20, 2010 | 07:06 PM
trophy's Avatar
trophy
You want a clamp with rubber/plastic jaws like this.....
File Type: jpg
Old Jul 21, 2010 | 11:10 AM
JPS's Avatar
JPS
Sounds like a 8-10' ratchet strap is what I need. Thanks all.
