Starting issue , any thoughts?
Today I went to take the 993 for a drive to get gas and go to the store.
I drive the car 2 or 3 times a month.
I went to start it and it didnt start, the engine would turn over and nothing check engine light was on.
The fuel level look low so I thought maybe I ran to low on fuel.
I added about 1 gallon , when in side for about a hour to do some other things and came out and it started.
I pulled it out and drove down the alley about 50 yrds and while climbing up a hill the check engine light came on and it died.
I let it roll down to level ground and waited a min and it started.
I did a lap around the house and drove streight to the gas station to fill up about 3 miles from the house.
I filled the car with it running and pulled out to the light , and it dies again , check engine light.
This time no starting , it would turn over and start to fire , then nothing .
I get towed home, and in front of the house it starts again , and I drive it around to the garage (100 yrd) died again , check engine light .
The car is a 1995 with 81,000 miles
is this the DME relay? or should I look at something else?
I wanted to see the forums thoughts before I tow it to the Porsche dealer.
Let us know how it goes.
Cheers,
Joe
