Recommended Tiptronic Transmission Fluid?
Hey guys, I'd like to change the transmission fluid on my 993 tip and was wondering what the recommended fluid was? As always, thanks for the information!
Used Redline Sythetic ATF. No issues.
see http://www.redlineoil.com/product.aspx?pid=50&pcid=9
Suggest replacing the filter and measuring the drained ATF volume carefully so you don't overfill.
A new sight gauge would be nice. Perhaps you can see the level better than in the photo.
You did have the engine running and the fluid warmed up?
It does not take long to dump some fluid from the quick fill connector using a plastic tooth pick or whatever to push the ball bearing up on the one way valve. Once the fluid has cooled down of course.
