Aftermarket keyless remote guts + Porsche hand remote housing
RR, I soldered this small lightbulb to the board. One pole at the minus coming from the batt. and the other one on the other side of the board placed at one of the terminals coming from the button.
I did this with the trail-and-error-method. Pressed the button (a bit further away from the vehicle) and just checked a few possible terminals, until the light went on when the button was pressed. It did not interfere when I checked this again near the car, so I soldered it on the spot and insulated the poles.
Btw, the bulbs were bought at some internet shop here in Holland. But you probably could get them anywhere on the internet!
Dear Marco,
Many thanks for this!
If my option A fails, I will order a Med System (in my case I only need a keyless entry module, as it can be easily grafted on the existing Porsche alarm) Anyway, the remotes seems to be the same for the keyless entry (TX 4000, TX4001). and funily, it happens that it might come from Holland too, as the nearest dealer I found for MED alarm kit is www.autosound.nl ...
many thanks again, I will let you know and post the results of my work...
Best regards,
Best regards,
