Wheel paint success!
After buying some used turbo twists I decided I would refinish one of them that had a few chips. I probably should have just left it. I did alot of research trying to find a color code match for the Porsche wheels. There is not alot of good info out there on this subject. Everybody recommends Wurth which is hard to get around here. I tried a few off the shelf wheel paints as well as some other Duplicolor silvers which were all too dark. A bodyshop supply place told me wheels couldn't be computer color matched and sold me some single stage paint that supposedly matched a paint chip I selected but after spraying 2 wheels with various spray parameters it ended up being too dark. I then found another bodyshop supply place that tried computer color matching and sold me some Dupont Chromabase NH583M (L) Honda Vogue Silver. This is a base/clear type of paint. Voila! It is very very close and the Porsche wheel paint is hard to match. It also sprays very nicely (even with a cheap mini HVLP gun) compared to some of the cheap paints I have bought. I don't want to say how much I spent on paint
but I probably could have got a wheel or two professionally done for the money. I might even spray my Cup IIs now. Hopefully this helps others who want to tackle this DIY project.
ps the pic show a newly painted wheel compared to an original. I haven't got them out into the sun yet but the colors are very very close.
I'm going to use a local sports car repair specialty shop to mount and balance the tires. They are into Porsches, BMWs and the like. They recommended waiting a few days before mounting my new Sumitomo HTRZIIIs. I guess if they mark the wheels up its not a big deal now
Nice! V Nice.....but as somebody said earlier you should try and bake them to harden them, it would be a shame to waste all the effort! Find a local spray shop and ask if you can put them in a bake when they are doing something else and iy may cost you very little or maybe even zero when they see the effort you have put in!
Nicely done Matt! I've got a set of turbo twists in the garage that I wouldn't mind touching up. I've never used anything but spray cans before though. Would I be able to get by with a 6 gal pancake compressor and where did you pick up your HPLV gun?
Thanks guys. I'll try and get a pic out in the sun today. Hopefully the color match is good (it seems to be) and everyone won't have to go through the same hassles as me.
I picked up a mini HVLP at our Harbor Freight equivalent (Princess Auto). It was $30 and is great for small jobs. I actually measured the paint mix out with metal kitchen measuring spoons. My compressor is a 120 volt 7 cfm unit with a 30 gallon tank. It's ok for the small HVLP but won't keep up on bigger jobs.
I think that paints cure chemically now and the baking applies to older enamel paints. Shops might use heat to speed the curing process up a bit though. I'll have to take my chances but I'll wait a week before mounting the tires.
