Steering Rack Mounting Bolts - Question
Did Porsche use some kind of loctite when mounting the steering rack?
I just removed mine (replacing it, leaking) and found a blue residue on the end of the threads and on the mounting bracket.
I have 3 of 4 of these bolts apparently frozen into the crossbar above the mounting brackets (I had to cut the bolt heads off to remove the rack!).
Besides drilling them out, any suggestions? I tried wd-40 and also tapping them lightly with a hammer, no luck yet.
AFAIK, there is a blue thread locker on these bolts - the 'solid' aerobic type [ which, BTY, can be refreshed with Loctite 242 blue liquid anaerobic type on reassembly.]
Both types yield to heat, so one option is to break out the torches and they can be taken up to "cherry red" if necessary: clamp on a pair of vise grips, and they should turn out easily.
A less drastic approach is to use a real rust penetrant, such as Kroil .... save the WD-40 for cleaning your hands. Soak, and then slowly work back & forth with the vise grips.
Another trick that often works is to smack the bolt head with a hammer before attempting to turn them out ..... at this late point, smack the headless bolt & see if that helps.
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
+1 on WD40 for hand cleaning only![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Its nearly kerosene anyhow.
Yes, these can be challenging to remove. A little heat would help as suggested above.
WD-40?
Makes a great bicycle chain cleaner.
POS as a lubricant.
