993 Forum 1995-1998
oil gauge range
Old May 25, 2010 | 01:14 PM
inkatouring's Avatar
inkatouring
From: nowhere, but at least I'm getting there fast!
Default oil gauge range
Does anyone know what is the amount of oil is indicated by the gauge between the red (low) and max and anywhere in between?
TIA
Old May 25, 2010 | 01:36 PM
TMc993's Avatar
TMc993
There is nothing in the owner's manual that references the quantative difference between any two points on the oil level gauge. Mine has grown so inconsistent that I don't even look at it.
The manual does state that the difference between the bottom and the top of the twist on the oil dipstick is 1.6 quarts.
Old May 25, 2010 | 02:12 PM
95 C4 993's Avatar
95 C4 993
The oil indicator (at least mine) indicates the following:
About 2/3 up the spril==about 1/2 way on the gauge.
About the middle of the spirl wont register on guage
Give or take a little on the above.
I like to keep my oil level about where it registers about 1/2 way on the internal oil gauge after warming up and being idle on flat ground. For me, thats a good indicator and consistant over the past 7 years. However, I always check the dip stick regardless what the gauge states.
Old May 25, 2010 | 06:45 PM
randytrish's Avatar
randytrish
My car needs around 1/3 to 1/2 quart from when the guage is registering at the bottom to move to the
3 o'clock position.
Randy
Old May 25, 2010 | 07:13 PM
mongrelcat's Avatar
mongrelcat
Some good info on rectifying the problem in JasonAndreas' posts #20 & #26 here:
https://rennlist.com/forums/993-foru...oil-level.html
I thought the range on the dipstick was 1.8qt, but after re-reading that thread it seems 1.6qt (1.5l) is right. And the range on the gauge is 1qt.
