993 Forum 1995-1998
Leak Down & Compression test from hell- Updated
Old 05-21-2010, 01:47 AM
Speedyellow993
Speedyellow993's Avatar
Hey Matt, Can you PM your number?
Old 05-21-2010, 02:35 AM
1pcarnut
1pcarnut's Avatar
Originally Posted by Ed Burdell
I'd trust your butt dyno here. The fact that the test results are so atypical, the test procedures highly suspect, AND you have a solid car to compare it to (back to back if you wish, even), makes me think you can purchase with confidence without a retest, so long as your test drive finds no issues.
I'm with Ed.
Old 05-21-2010, 09:16 AM
Cactus
Noodle Jr.
Cactus's Avatar
Originally Posted by Speedyellow993
Hey Cactus...you noodle!! You are good with 4400 miles and half a bottle.
PS. Why am I an addict? I'd rather be a noodle !
I figured that was pretty tight then. As for the Noodle thing.....don't ask
Old 05-21-2010, 10:13 AM
jdistefa
jdistefa's Avatar
Just left you a message
Old 05-21-2010, 11:01 AM
Martin S.
Martin S.'s Avatar
Default Mike Schatz
Originally Posted by Reddy Kilowatt
My PPI guy (Michael Schatz) didn't think a leakdown & compression test was important (or even necessarily a good idea) if the car didn't exhibit any symptoms that warranted it.
Mike is one world class wrench...sort of lost track of him, he was at Rusnak in Thousand Oaks...
Old 05-21-2010, 11:24 AM
Slow Guy
Slow Guy's Avatar
Not even a full Noodle, he's a Jr. Noodle....
Old 05-21-2010, 12:46 PM
axl911
axl911's Avatar
So what would qualify as symptoms?
- weak/loss of power?
- making funny noises?
Old 05-21-2010, 02:09 PM
Reddy Kilowatt
Reddy Kilowatt's Avatar
He had his own shop when I was down there buying the car. I found this elsewhere on Rennlist...
https://rennlist.com/forums/993-turb...-business.html
Old 05-21-2010, 02:11 PM
Reddy Kilowatt
Heck, I don't know. Ask Mike.
I think he was focused on power, significant oil requirements, etc.
Old 05-22-2010, 09:37 AM
IXLR8
IXLR8's Avatar
Originally Posted by IXLR8
Where is that spec located? I couldn't find it listed in the Service Manual.
I guess nobody knows...PSI number was pulled out of a hat.
Old 05-22-2010, 11:25 AM
Fred's 964
Fred's 964's Avatar
These numbers do not make sense. If they did a leakdown test at let's say...140 psi, some of the percentages are close if calculating after leakdown, but others are not. I've not seen numbers posted like this. Leakdown tests can be done with different pressures, we use 80 psi on aircraft engines and list the pressures held (76 psi, 78 psi, etc) The method used and the skill of the mechanic can make these numbers fluctuate up or down, usually down. I would only have someone I trusted do it if I didn't do it myself.
Whats with the @10 psi # on the original post. If they cannot explain themselves, I would argue with them about payment for some meaningless numbers. You may be in a position to negotiate a lower price and/or write it up to a bad experience.
All the cylinders are all within a few psi, so whatever they stand for, the engine probably runs smooth....
but you probably knew that when you drove it in...
Old 05-22-2010, 11:38 AM
IXLR8
IXLR8's Avatar
Originally Posted by Fred's 964
Leakdown tests can be done with different pressures, we use 80 psi on aircraft engines and list the pressures held (76 psi, 78 psi, etc) .
And its so nice to be able to grab hold of the prop and rotate it back and forth...beats trying to work with a pulley bolt.
I did the same thing you did and wondered why they would use 137.5psi (I used the first number: 1/0.88 x 121)...and then some of their psi numbers are different for the same percentage. Whats with that?
Old 05-22-2010, 05:47 PM
Fred's 964
Fred's 964's Avatar
That mechanic skipped his 5th grade math class...... Hey Alex, nice choice of color on your 993....
Old 05-22-2010, 06:53 PM
IXLR8
IXLR8's Avatar
And when I saw the ad, I thought I'd never go for it. I always wanted the typical German color...silver. Heck, everybody has that...and black.
Old 05-23-2010, 12:25 AM
Speedyellow993
Ugh! You guys are killing me! SPeed Yellow Rocks!
Quick Reply: Leak Down & Compression test from hell- Updated
