RSR Ride Height Specs???
I'm playing around with different setup options on my 1995 993. Anyone have the RSR ride height specs?
My car is track only with all the necessary goodies to handle it.
Jeff
Jeff
Before trying the GT2 settings you may want to have a look at rear a-arm angles as the GT2 used 26.7" (or 28" for the goodyears) tall tires.
If you set the rear of your car to 92/93 mm you may have some unusual toe and camber changes on suspension compression.....
If you are using 680 tires, go for it...
The RSR's were the same width as the 993tt's and not as wide as the GT2, your point is valid regarding setting up a NB car to RSR height.
