Help with oil leak
Help with oil leak
I just notice a small pool of oil under the rear right jacking point today. Last drove the car Tuesday. Last oil change was November. I checked the wheel well and found no oil leaking around the drain plug, filter, or the visible oil lines. I started up the car until warm and got a couple drops to leak but I can only see it as far as the tub nearest the jacking point and could trace it no further.
Appreciate any suggestions.
I'm suspecting a leak from the oil filling hose that runs from the engine bay to the oil tank. I disconnected the ends but it doesn't pull out easily. I don't want to tear it, especially if it's not the culprit
Any ideas?
BTW, checked filter, thermostat, drain plug and fittings to the oil tank...no leaks.
Any ideas?
