Drain tube next to brake fluid reservoir?
I deleted my vent pipe recently. Capped off the nipple on the side of the reservoir, and replaced the the non-vented reservoir cap with the updated vented one. EZPZ
Seared
After spilling several liters of RBF on my garage floor, I put a big sign on my Motiv brake bleeder reminding me to cap off the brake fluid vent pipe. I finally got around to replacing all that crap with the replacement cap that vents into the frunk, per the TSB Bulletin . I think I’d prefer spilling brake fluid into the street, but honestly it’s never had to vent in any of my cars and the new cap is simpler, and lighter.
Or get the newer style reservoir without the vent hole that you need to cap? Also, does the vent pipe just pull up and out of the wheel well or is it more involved to properly get the overflow pipe out of the frunk?
You can simply remove these two pieces and leave the rest of the pipe for later, if you’re weight conscious
