993 Forum 1995-1998
18-inch tire pressures for street
Old 04-21-2010, 05:13 PM
  #31
Stuttgart951
Stuttgart951's Avatar
Originally Posted by Avid Fan
36F/38R.
+1
Old 04-21-2010, 05:34 PM
  #32
Allen
Allen's Avatar
I run: front = 36 psi rear = 40 psi
Old 04-21-2010, 09:17 PM
  #33
Ed Burdell
Ed Burdell's Avatar
Originally Posted by speedbump2
Sounds like you might need a good all-wheel alignment to sort out your rear
camber & toe. You should probably get at least 10k out of the Sumis unless
every trip to the store is a Kamikaze mission for you
More often than not, the manufacturer's recommended tire pressures
are guided by liability concerns, rather than performance or economy.
They usually list the pressures best suited to a maximum load.
This can be traced back to the Ford Explorer/Firestone fiasco where tires
that were technically under-inflated in relation to their load, failed.
--Chuck--
Emphasis on the word "good" alignment. I've had it checked twice now and have been told by two shops that it's a combination of the widebody and the lowered suspension that leads to accelerated tire wear relative to other 993's. Not quite sure I'm buying that yet.
Old 04-21-2010, 10:04 PM
  #34
speedbump2
speedbump2's Avatar
Originally Posted by Ed Burdell
...it's a combination of the widebody and the lowered suspension that leads to accelerated tire wear relative to other 993's. Not quite sure I'm buying that yet.
Maybe you're at the adjustment limit on the rear lower control arms.
Are there any aftermarket control arms available for your car?
--Chuck--
Old 04-21-2010, 10:12 PM
  #35
Slow Guy
Slow Guy's Avatar
The second paragraph explains what I was saying earlier:
Those pressures printed on the door sticker are for max load only.
It's a liability issue.
--Chuck--
I didn't look at the 993 door sticker today but I know on my other 3 cars there are 2 pressure readings on the stickers. One for moderate load (couple psgrs. and little luggage) and one for full psgrs. and full luggage.
Old 04-22-2010, 04:03 AM
  #36
Canyon56
Canyon56's Avatar
Originally Posted by VMXWinn
I run 34 front / 36 rear on 225/285 PS2. Great overall combo in ride vs stick.
Me, too.
Old 04-22-2010, 08:42 AM
  #37
speedbump2
speedbump2's Avatar
Not that there's any corrolation, but my VW has the same width 18" tires all around, and has the same 36/44 psi (cold) recommended on the door sticker.
With the way the car is weighted, I've found 38 psi (cold) all around to be optimal for the street, and I knock them down to 35 psi (cold) all around at the track.
But that's the same tire size all around. You guys would probably benefit with a little more psi in the rear than the front, but 44 psi seems a little excessive.
--Chuck--
Old 04-22-2010, 02:42 PM
  #38
PNogC2S
PNogC2S's Avatar
This is has been an interesting thread. Now I'm really confused.
Last year I did one of those Jim Russel Racing track day/schools where you take your own car out and they teach you some track driving basics.
The first thing the instructors did was have everyone drive over to the pits and pump up tires to maximum (door sticker) pressure + 2lbs. front & rear... Any speculation on why they would do that for a track session? Sounds like most guys here are using lower pressures for the track.
Old 04-22-2010, 08:43 PM
  #39
Matt Lane
Matt Lane's Avatar
I could only guess they wanted you to learn at lower speeds with the absolute minimum traction possible from your tires? You'd be running on the centers at those pressures, I'd think.
Track pressures are dictated by optimal HOT tire pressures, which in turn vary based on tire spec/compound. But if a tire likes 38 hot, then you'll have to start many pounds lower cold to account for the buildup of pressure from hard track use and resulting heat.
M
Old 04-23-2010, 01:49 PM
  #40
PNogC2S
PNogC2S's Avatar
Yeah, that's why I'm so confused by this whole thing...it seems crazy to intentionally put students out on a track with tires set up for minimum traction... and it was a hot day at Infineon too boot... so those tire pressures had to have gotten pretty high!
I was on nearly new PS2's and I have to say they stuck very nicely...the instructor assigned to me, who was very familiar with Porsches, took me around a lap to show me what it could do and... WOW! the speeds were amazing (to me anyway) and we weren't slipping and drifting around... just tracked a nice clean line. Oh well...another one of those mysteries I guess.
Old 04-23-2010, 06:01 PM
  #41
hoggel
hoggel's Avatar
An engineer cannot let a discussion of numbers go by without jumping in.
Regarding recommended tire pressure in 17s vs 18s on the same car. The compressed air volume (measured at the boundary as tire pressure) and sidewall strength is what carries the car. Tires spec'd for the same car in 17 or 18 are approximately the same diameter. That means the 18s have about 15% less air volume to carry the same load. The compressibility of air is not linear so the smaller volume must be at a higher pressure to carry the same load.
When a tire hits an uneven spot/thing on the road the tire shape deflects until the air pressure inside equals the force of the impact. With a 17 inch tire there is more distance from the impact to the wheel and more air volume to compress so it can safely operate at lower air pressure. That’s why the ride is softer on 17s, they are absorbing impacts through a longer range. But that ride comes with compromised sidewall flex and contact patch.
Ed, my C2S eats rear tires. If I get 10k out of a street pair I’m excited.
My bottom line? The tire pressure depends on the car (weight), the tire size and construction, and the driving conditions (surface, temp, lateral loads, …). The factory recommendations are a conservative place to start. I run 36psi in the front all the time. At the track (DE, smooth track) I use 38psi hot in 295/30s on the rear. On the street I put 40psi cold in 285/35s to protect my wheels. Yokohama A048s on the track and Pilot Sports on the street.
Old 04-23-2010, 06:15 PM
  #42
24FPS
24FPS's Avatar
f:36
r:38-40
cold
bridgestone potenza re-11 on a cab
Jbelt01 (02-15-2022)
Quick Reply: 18-inch tire pressures for street
