RS and NB rear fender support brackets???
Read a little blurb in the back of this month's Panorama...said that RS cars had a longer rear fender support bracket which would fit all NB cars, insinuating one could get a slightly fatter rear fender by installing this bracket?
So A) not sure I interpreted that right; B) not sure what would be involved in replacing said bracket, and C) not sure if there would be any downside. BUT getting a slightly fatter butt without building a WB cab is an interesting prospect.
Thoughts?
Thoughts?
I know the point where the bracket fits could help those with rubbing issues, My rubbing (when the car is very low) occurs right where the bumper joins the fender.
Can't add a response to your pondering's but am interested in the result.....
Thoughts?
Thoughts?
They just pull the existing B/C out to match the newly extended mounting holes.
You can "stretch" the rear of the B/C at least 1 1/2 inches this way.
have fun
Craig
Seared
It's true, the RS fender support bracket (above the muffler can) is wider. To install, the fender simply needs some gently persuasion outwards...
Andreas
Andreas
That answers part of it then (btw...what is B/C?)...it seems it just widens down by the mufflers, not up by the top. Makes sense, but I was hoping for some magic beans...
yes, it just widens the area behind the wheel, probably keeps stuff from being thrown up off the tires onto the paint
from what I've seen 285/30 on 10ET65 is not going to be an issue even on a very low track car, especially one that is sets up w/ a bit more camber than the usual street car.
When I buy a new set of rear wheels it will probably be 10.5 ET67-69, the 285/30 is is about ideal for a tire size
btw
993.505.641.02 support tube /L $136.63
993.505.642.02 support tube /R $136.63
King of Cool
King of Cool
Flying Finn,
I love that exhuast, I always wondered why no one routed it that way (without the extra loop, like the supercups have.) Very clean looking.
Thanks for the posts. I read the same article this evening and then stumbled upon this thread googling for answers.
Super Duper Moderator
I removed the rear bracket on each side inside the rear bumper (to save weight) and it has had no adverse result on the rear bumper cover.
Marc
Marc
You can definitely push out the rear end and just shim the existing bracket on the tub side. I would not want this pushed out without the front flared a little more also. If you install GT2 flares, it makes a big difference on clearance (315 fits well in the rear). Then you need to fab a need fender liner for at least the forward section.
