993 Forum 1995-1998
993TT Indicator Lights...
Old Apr 12, 2010 | 08:22 PM
HT5's Avatar
HT5
6th Gear
Default 993TT Indicator Lights...
Greetings. I'm the proud owner of a "new" 993 TT (1996). I took it to the track today and it performed admirably until the ABS lights and anti-lock lights came on. The breaks felt fine so I assumed that the heat got to them and a cooling off period would help. After taking a pit and shutting it down, I restarted it an hour later to see if the warning lights were still on - they were. I shut it down again for about 1 minute before a friend wanted to see the lights. When I turned the key again, I got clicks - dead battery? I jumped it, tried a slow lap, and the engine died as I was pitting again complete with battery, hand-brake, check engine, and most other lights lit. The car is now on it's way (via a flat-bed) to the Porsche dealer. I'm a Porsche novice but it sure felt like the battery was not re-charging - alternator problem? I will get a diagnosis from the shop tomorrow. Any ideas?
Thanks...
HT5
Old Apr 13, 2010 | 02:08 AM
Full Boost's Avatar
Full Boost
Why do I feel so left out!
HTS,
Yes 100% an Alternater issue....
My guess is that one of your belts let go. This "MAY" cause the 2nd belt to "jump" track also - giving the appearance all is ok - but it aint.
Order 3 x New PORSCHE belts - re-install = NO lights
Simon.
Old Apr 13, 2010 | 09:56 PM
HT5's Avatar
HT5
6th Gear
Thanks Simon. Looks spot on - Broadway Porsche in DFW is replacing belts tomorrow...
HT5.
7 Porsche Models That Have Aged Like Fine Wine
Slideshow: Some Porsches have become icons with age, proving that great design doesn't follow trends or expiration dates.
By Verdad Gallardo | 2026-06-16 13:40:23
