Help - CDR 220
I guess this question is a reflection of just how often I use the radio and what an electronic clutz I am.
How do you manually tune to a radio station? Every time I turn the right rotary **** the radio scans. Which where I live is bad because station reception is poor and so it only stops on about two stations. I'd like to set the precet buttons but can't manually tune to the station.
Read the manual and can't seem to figure it out.
Help!
Help!
http://www.beckerautosound.com/pdf_guides/om43-4462.pdf
First press the Function button with "arrow pointing down" symbol
Then tune with the right rotary ****
canysmc:
Thank you. This is a great place. I sat for 15 minutes today with book in hand and couldn't make it work. Probably the only button I didn't try.
Z
Z
