OK Uncle: Powerpoint 2007 music with all the slides
Location: Lat: 47 Deg 26.848N Lon: 122 Deg 21.341W Seattle
HELP!!!
We spent all day trying to get a two and a half minute music WAV file to play with all of the slides and not start over on each slide.
Been on Google and tried all the tricks there.
Something is causing the sound to start on each slide....arg. We are not experts but none of the help addresses the issue.
Hoping there is a wizard out there.
Thanks!
Thanks!
Thanks Mongelcat...we have been to that site and have done everything as it shows.
We must have something else screwed up.
Thanks!
Thanks!
Check that the machine has had all Windows Updates applied. Then make a new presentation with just a few slides, and try the wav with the settings above. If that doesn't work, try a different wav file. If that doesn't work, try a different machine.
Started a new Powerpoint instance and simply copied the info of the slides into the new one. I will now work!
Thank you, thank you, thank you.
Seriously, we spent all afternoon til 8 PM on it. This seemed to fix what ever setting was hanging up.
Cheers!
Cheers!
