Help needed for removing the heat exchanger pipe running through the passenger’s side
Hi Gents
I’m in the process of changing a damaged rear fender and need to lastly remove the heat exchanger pipe that runs through the passenger’s side sill. before cutting the damaged rear fender out.
I have undone the two screws at each end of the pipe and thought it would all simply pull out via the front but it just seems to want to stretch![Frown](https://rennlist.com/forums/images/smilies/frown.gif)
Is there anything I have missed as Porsche got them in there so they must be able to come out.
Some pics of the offending item:
![](http://www.deutschnine.com/rennlist/993-heat-exchangers/heat-exchanger-01.jpg)
Which I gather should pull out of hear:
![](http://www.deutschnine.com/rennlist/993-heat-exchangers/heat-exchanger-02.jpg)
Your help and any suggestions will be much appreciated![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Regards,
Mark
Regards,
Mark
