Instrument Trim Rings
#121
I tried the poster tape...trust me...you need the exterior mounting tape for its thickness and adheisive qualities. the rings have a bit of space in there that requires a thicker tape. There is some space between the ring and dial edge but once installed with this tape, there is no visible space and the fit is perfect
#123
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Update -- I have another 30 sets done and will ship today and tomorrow.
One question: I have received a money order from B Wilson in Philly -- what is your screen name??
#124
Ha! Just noticed this thread bumped up...I was wondering what happened with this project...was not getting subscription email updates either. Just sent you payment Chris...hope I'm not too late to get in on this! Thanks again for all your efforts.
#126
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
No problem, gotcha on the list. Thanks for payment!
#127
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Trying to shake this jetlag -- ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
I have the last wave of 30 sets of these rings now and will ship out tomorrow to those who have paid and on the list.
There are folks whom I havent heard from, they are:
corrdobrit
shu
sonny1
macca
shldrdoc993
black 993
arenared911cab
matt777
85charles
If those on this list would send me an email at cwalrod@sbcglobal.net, that would be greatly appreciated!
corrdobrit
shu
sonny1
macca
shldrdoc993
black 993
arenared911cab
matt777
85charles
#129
I have mine for a long time, and I put it at the bottom edge, not the part contacting the glass. Cut a VERY thin strip. If you put it at the top, it will create a gap between the ring and the gauge.
#133
ditto, I cut very thin (in tape width) strip, used 4 per ring, put them at the bottom/middle inner edge of the ring. I'm sure I didn't get the rings all the way 'in' so they're flush with or contacting the glass, but they look good enough for me. In a couple cases (more the outer smaller gauges) the top of the ring edge protrudes just a hair 'taller' than the gauge outer bezel, but then I'm a DIY neophyte and screw up most everything I touch (there's a thread on light switch bulbs where I got so beaten up I lost my temper in response). But mine look good enough to me, certainly a big improvement especially when one has aluminum on the handbrake or shift lever.
#134
The lighting makes the plastic airbag look different than the leather wrap....
I don't know how some folks can live with a pitted trunk hood...I would not be able to sleep at night.
