Which spark plug wire is this? Help Please.
Where does the spark plug wire labled 1-5 go to?? (Which Plug?)
I have ruined it
and wonder how hard it is to access the plug it goes to so I can replace the wire?
Thanks!
I have ruined it
![crying](https://rennlist.com/forums/graemlins/bigcry.gif)
Thanks!
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Agent Orange
At this point it may be more cost and labor efficient to get a crimping tool and buy the plug and fix it, instead of having to buy the whole ignition wire and disassemble the intake.
Guys,
In looking at the related photos I am seeking help on removing the primary (?) distributer cap that is the lower one. I have done a search and read Robin's original posting in Distributor cap/rotor R&R. I got the upper one done and as "Bozo" said I am now running on 1 1/2 plugs/cylinder...that guy is a riot!
Anyway, any tips before I strip out the lower screw of the lower distributor?
accessing the plug isn't too bad, there are maybe 2 of 12 that are harder to get to...., but removing the looms from the fan housing if you don't remove the varioram IS NOT FUN.
#1 on buying a crimp end and trying to repair existing wire first.
Mark Robinson might sell you one.
http://forums.pelicanparts.com/porsc...red-black.html
good luck
as you've seen above, I - 5 = Intake plug of cylinder #5.
good luck
good luck
Thanks for the tips guys...I should know better than to pull on the wire but impatience got the best of me. I am going to have my local Porshce guy see if he can repair the wire tommorow as i have a road trip planned for this weekend! Wish me luck and next time I will...........
![manual](https://rennlist.com/forums/graemlins/rtfm.gif)
The Beru M3 threaded sleeve terminal ends are threaded and screw into the caps.
You can get them from either Porsche or Kingsborne.
Porsche part number: 911 609 310 00, $1.17 each from Sunset.
Beru part number: 0901300003
The downside is the cost of the crimping tool: $325 and worth every penny, I am sure. A rental loaner would be nice.
