993 Forum 1995-1998
Paint question
Old Mar 25, 2010 | 03:03 PM
Reuben's Avatar
Reuben
Default Paint question
I recently had a partial cosmetic re-spray, which worked out well apart from a few spots that I was not happy with. Car is going back next week to have these issues rectified, so I just wanted the opinion of Rennlisters first:
At the joint between the front wing and the base of the A-pillar, paint is peeling already. Body shop says that it cannot get a better result without removing the gasket, and as the gasket has holes in it where the bolts go through, one basically has to loosen the wing, remove the gasket, paint, then re-weld the wing.
Does anyone have experience with this? I think this is partial BS as they have managed to paint the other side very nicely right up to the gasket, and it has not peeled at all (yet).
Thank you,
Reuben
Old Mar 25, 2010 | 03:25 PM
vincer77's Avatar
vincer77
Is that the gasket between the front fender and the body? First of all, I'd definitely have that checked out for rust. The gasket is pretty simple to remove and replace. There are some bolts that attach the fender to the body. Those need to be loosened and the gasket slides right out. If they are old - replace them while you have them out.
Old Mar 25, 2010 | 10:59 PM
SKM's Avatar
SKM
Peeling is due to poor surface prep and the masking edge created by the fender bead not being removed. I've been told it is a PITA to loosen the fender and remove that beading however others have said it is not that difficult. I am sure it saves an hour or two of labor to leave it in place. Seems to me the only way to correct it is to remove the beading, sand it smooth and repaint. Perhaps a minor color blend can be accomplished with a small paint gun/air brush, then clearing, rather than repainting the entire fender.
Old Mar 25, 2010 | 11:23 PM
theporscheguy's Avatar
theporscheguy
I have had paint shops work up to beads without an issue. Your shop needs to repair this spot correctly. I thought the purpose originally was to make your car better. You don't want to look at this every time you get into your car a be reminded of a substandard job.
Old Mar 26, 2010 | 12:28 AM
Leander's Avatar
Leander
Perhaps a good lesson as to why a repaint should be considered as a final option only.
Old Mar 26, 2010 | 12:56 AM
1pcarnut's Avatar
1pcarnut
It would appear poor prep near the edge is the problem. The fender should not have to come off to fix but those paint edges need feathering and blending or they'll show.
Old Mar 26, 2010 | 01:43 AM
porschemikeandnancy's Avatar
porschemikeandnancy
Agree with SKM - poor surface prep. They owe you a re-spray just on that area. They should be able to propertly blend it with the rest of the new paint.
I would not worry about the re-paint of the re-paint. When you ultimately sell your car, I would not try to hide that it has been re-done. Depending on the reason, it should not (if properly re-done) detract too much from your car's value.
Old Mar 26, 2010 | 02:07 AM
gyrfalcon's Avatar
gyrfalcon
Former Vendor
Default I had the same issue...
shortly after I bought my car. That area had just been repainted by the po's body shop, and they were too lazy to remove the gaskets to do the job properly. I then had a competent body shop remove those gaskets and discard them, repaint the car, and put in new gaskets. That is the proper way to do it, and it looks perfect, just as it should if done correctly...and no welding was necessary to my knowledge.
Old Mar 26, 2010 | 08:25 AM
Arena993's Avatar
Arena993
I did an entire repaint on my car. IMHO remove the gaskets, spray the fenders and replace with new gaskets. The way it should be done.
Mike
Old Mar 26, 2010 | 09:25 AM
Allen's Avatar
Allen
+1
Old Mar 26, 2010 | 09:36 AM
cabrio993's Avatar
cabrio993
My car had a total respray. The fender bolts have to be loosened, and the gasket comes right off without the need of removing the fender. Replace with brand new gaskets. They are cheap and the old ones are probably hard and brittle by now.
Old Mar 26, 2010 | 11:47 AM
SPD YLO's Avatar
SPD YLO
+1
Old Mar 26, 2010 | 11:53 AM
JPP's Avatar
JPP
Exactly. Welding? They don't know Porsche, take it to someone familiar with these cars and have it corrected correctly. The value of your car is in the body ...
Old Mar 26, 2010 | 12:14 PM
AOW162435's Avatar
AOW162435
Seared
Originally Posted by JPP
Exactly. Welding? They don't know Porsche.
Actually, there should be a small weld at the top, rear area of the fender (from the factory). Whether or not that gets replicated by a body shop is another issue.
Andreas
Old Mar 26, 2010 | 03:35 PM
JPP's Avatar
JPP
Andreas
Well, I stand corrected then. I thought these were the same as previous 911's with a bolt on front fender .. At any rate, I still believe you can remove and replace that welting strip without removing the fender to properly paint in that area.
