Wheel well liner with Turbo nose
I posted this parts list to help everyone out - replace whatever parts you desire, depending on whether you want an OEM result or not.
The hardware items are a few cents each usually. I said in my original posting that I bought extra and used them in other places. The first half of the list are the items that are expensive and that I wanted to replace to make the conversion OEM as possible.
The items such as 'sealing' are the foam seals that direct airflow through the two heat exchangers. They will fall apart when you take the bumper cover off. The 'retaining bows' are usually corroded. 'Wheel housings' and 'brackets' are specifically to mount the TT bumper cover.
Here is what you need:
PRICES ARE FROM SUNSET PORSCHE
1 – 993-504-125-01 wheel housing – LH. $58.00
1 – 993-504-126-01 wheel housing – RH $58.00
1 – 993-505-793-00 support bracket $5.62
1 – 993-505-794-00 support bracket $5.62
1 – 993-631-181-00 retaining bow $3.62
1 – 993-631-182-00 retaining bow $3.62
1 – 993-631-141-01 vent drain $1.25
4 – 999-190-104-30 rivet $0.23 EACH
4 – 999-591-764-02 speed nut $0.23 EACH
6 – 999-591-699-02 speed nut $0.23 EACH
10 – 999-507-442-02 speed nut $0.23 EACH
8 – 999-073-081-02 tapping screw $0.23 EACH
10 – 900-187-103-02 screw $0.23 EACH
20 – 900-143-159-07 screw $1.52 EACH
10 – 900-143-113-07 screw $0.48 EACH
20 – 999-498-008-40 plastic nut $0.12 EACH
4 – 900-145-092-07 tapping screw $1.21 EACH
4 – 900-075-260-02 bolt $0.48 EACH
4 – N-011-666-7 washer $0.23 EACH
4 – 999-704-150-40 washer $2.40 EACH
10 – 999-591-485-02 speed nut $0.23 EACH
There are also rubber seals that go between the bumper and the headlights on the left and right side as well as the large seal between the bumper and the deck lid. They are as follows:
1 - 993-505-544-00 $29.84 Rubber Trim
1 - 993-505-543-00 $29.84 Rubber Trim
1 - 993-505-143-01 70B Ceiling strip $76.57
