Thoughts on Bilstein RSR's?
Thanks Matt.
Helpers strictly speaking have a very low spring rate and act only to keep the main spring seated with the suspension is unloaded.
Well said, Doc,...
There are big differences between tender springs and helper springs.
The former comprise an active component of the total spring system and its overall rate (the relationship is somewhat complex). Helper springs OTOH, are there simply to ensure the main springs cannot fall out of their perches at full droop and play no part of the overall spring rates.
Tenders offer a "dual rate" spring system where by adjusting the lengths of the mains and tenders, one can design the place where the main spring begins working. This offers a degree of compliance using high rate springs to conform to road/track irregularites and small bumps and keep the tires on the ground.
Naturally, this is a gross simplification of this subject but hopefully, you get the idea,...
FWIW, here's a good website that I read (and re-read... and re-read) when I was trying to get my head around suspension component design, setup, and tuning. Of course, it's still mostly over my head, but I keep reading, adjusting, drinking .
http://www.pirate4x4.com/tech/billav...lovers/Part_1/
After reading some more posts, it seems that I should be okay with my factory uprights assuming I don't lower the car below RS specs, which I don't want to do. Any comments on this would be appreciated.
I think I might pursue this further...
That being said, who is actually running the Bilstein RS shocks here? There is a used set on Ebay for $300 but the mileage is so high that the cost isn't a good comparison. How much should I look at paying for a used set (less than 1K miles)? They have been sitting on a shelf several years.
Thanks again everyone!
It's beyond me why anyone that doesn't want to lower their car and install the necessary additional parts to complete the suspension setup would want to put what are essentially racing parts on their car.
For stock height, street use why wouldn't you just get a regular set of Bilsteins?
I thought that RS ride height WAS fairly agressive/low.
The whole thing stemmed from me wanting to gain some high speed handling capabilities. I was thinking about getting some Bilstein HD's or some Koni's when a friend said "Hey I got some Bilstein RS shocks I could sell you."
Eventually I wanted to lower the car a little anyways, so this just seems like a good opportunity.
