993 Forum 1995-1998
993 Oil Separator
Old Feb 18, 2010 | 11:53 PM
Ern's Avatar
Ern
Default 993 Oil Separator
I took my 1996 911 to the dealer because the Check Engine Light came on. Replacing two sensors did not solve the prolbem. They them found that the oil filler tube was cracked. They replaced it and solved the Check Engine Light problem and informed me that the oil separator was the cause of the cracked oil filler tube due to harsh vacuum. They say the oil separator needs to be replaced.
They are charging me $300 for the oil filler and labor and are asking $1,200 labor and $125 parts to replace the oil separator. I think the engine needs to be removed to do this job. Is there a way to replace the oil separator without removing the engine?
Old Feb 19, 2010 | 02:06 AM
AOW162435's Avatar
AOW162435
Seared
Our cars have oil separators?
I never knew. I think you're about to get taken to the cleaners on this one...
Andreas
Old Feb 19, 2010 | 04:55 AM
Steve Weiner-Rennsport Systems's Avatar
RL Technical Advisor
JMHO, but I think you need to get another opinion. It sounds like this dealer may be trying to improve their month by telling you that the non-existent "oil separator" needs replacement.
This is a part indigenous to the water-cooled cars and problematic to boot. The air-cooled models don't have such things and its possible they cannot tell the difference.
I cannot offer specific recommendations, but I'd find an experienced and honest shop well versed in air-cooled cars to see what you have going on.
Last edited by Steve Weiner-Rennsport Systems; Feb 19, 2010 at 02:03 PM. Reason: Clarity
Old Feb 19, 2010 | 11:29 AM
Leander's Avatar
Leander
My oil filler tube cracked and broke into little pieces, some of which went into the oil. This did NOT result in the CEL coming on.
Old Feb 19, 2010 | 01:36 PM
MarkD's Avatar
MarkD
For fun, ask them "this would separate the oil from.... what exactly?"
+1 to what Steve said...
run!
Old Feb 19, 2010 | 01:40 PM
jscott82's Avatar
jscott82
Exactly what I was thinking....
While they are at it, ask them to change your muffler bearing and check the headlight fluid...
Old Feb 19, 2010 | 01:46 PM
NP993's Avatar
NP993
And maybe request a proctological exam while you're in there.
Old Feb 19, 2010 | 05:15 PM
chris walrod's Avatar
chris walrod
Guru
Rennlist Small
Business Sponsor
So, which one is it? a 993 or 996 -- WTF???
https://rennlist.com/forums/996-foru...separator.html
Old Feb 19, 2010 | 05:23 PM
jdistefa's Avatar
jdistefa
Hmm.... trolling?
Old Feb 19, 2010 | 05:33 PM
GeoT3's Avatar
GeoT3
all may sound funny but not coming from a "dealer"... I hope he meant indie
Old Feb 19, 2010 | 05:34 PM
GeoT3's Avatar
GeoT3
must be a 1999... keys on key board are close....
Old Feb 19, 2010 | 06:34 PM
epj993's Avatar
epj993
You might also have them check the Johnson Rod and muffler bearings Sounds like crap to me.
Old Feb 20, 2010 | 09:52 PM
Ern's Avatar
Ern
The car is a 1999 and is a 996 and shouldn't have been posted on a 993 site, sorry. Many figured that out right away. For you 993 fans, be glad that you don't have an oil separator. They seem to have a reliability problem and in order to replace the $150 part, one has to remove the engine on the Tiptronic model. Some say that it is possible to move the engine but I don't think I want to learn how to move the engine or remove the engine. I have spent my Porsche days for the last twenty years working on 928s, you know, Porsche's Corvette.
Thanks, Ern
