Idle Control Valve
Anyone ever replace the Idle Control Valve and have an improved idle? After many adjustments my car idles somewhat smooth but tends to float between 850 and 975 rpm. I have driven a 993 turbo of a co-worker that has a very nice idle. Wondering if it is worth changing out. Also, I noticed the Bosch ICV are more expensive for Porsche than BMW's. Same design/look although the part # is different.
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
They do wear out now that these cars are getting older. Some dont respond well to just cleaning -- replacements are needed from time to time.
Try a good cleaning first before spending the $$ to replace. A can of brake cleaner (or simliar) is cheaper than a new part...
http://www.pcarworkshop.com/index.ph...-_ISV_Cleaning
Miy 993 hunts up & down for a few seconds during very cold weather then sets into a steady idle. Just clean it-dont buy a new one.
Had the same problem on my 78 911 SC & 86 928S. Unfortunetly those cars had hunting idle problems even during warm weather & were 20 plus years old so i replaced the stupid valve. There are deals on ebay for these parts.
Good Luck
Good Luck
