A/C Oil Quantity Question?
I am running low on Freon, and instead of just recharging my system, I have decided to actually try and fix a couple leaks around the expansion valve.
(I am keeping my fingers crossed as far as the evaporator is concerned!)
I bought a new expansion valve, as well as a new dryer from Pelican. 3 cans of Dupont Freon, 8oz of PAG 46 with UV Dye from PepBoys. Some Gauges, and a cool Vacuum Pump from Harbor freight.
I also got O-rings from Sunset, before finding out that the Pepboys O-rings are identical:-(
I have a hard time understanding my 993 Manual. How much oil do I need to physically add to the system after I have replaced all the components?
40cc lost when the system is depressurized + how much for the valve? + how much for the new Dryer?
I am not planning on opening the compressor, unless somebody tells me otherwise.
Thanks,
Thanks,
