993 Forum 1995-1998
engine shuts off
Old 02-03-2010, 10:18 AM
CalvinC4S
CalvinC4S's Avatar
Definitely worth a shot, but I belive the fuel pump to be on the same circuit as the ECU just after the DME relay. It has been my understanding to listen to the fuel pump as it will tell you if your getting power to the ECU/DME
Old 02-03-2010, 04:23 PM
J.B.H.
J.B.H.'s Avatar
Half Dead DME...had the same issue...
no ghosts...
Old 02-04-2010, 12:02 AM
CalvinC4S
CalvinC4S's Avatar
The only thing throwing me off is that his fuel pump is still running, which is on the same side of the DME relay as the air mass sensor.
Will a DME relay fail in a closed condition tripping up the airmass signal (due to continuity) while keeping the fuel pump running? Then work again for a few weeks 2 minutes later?
Old 02-04-2010, 01:58 AM
aclt993
aclt993's Avatar
Hey, to all those who helped me through this I want to thank you from the bottom of the undercarriage of my 993. I have my car back and you were correct in your diagnosis , it was the DME . She runs like a top and I'm back to being the driving fool I am . Thanks again.....KC
Old 02-04-2010, 01:24 PM
ard
ard's Avatar
Please clarify, if you don't mind: was the culprit the DME RELAY (cheap part), or the ENTIRE DME (aka Motronic - very expensive part). I am guessing you mean the DME RELAY.
Glad to hear this is solved, by the way.
Old 02-04-2010, 03:40 PM
aclt993
aclt993's Avatar
just the cheap part, the DME relay
Old 03-09-2010, 04:44 PM
J.B.H.
J.B.H.'s Avatar
I was referring to the DME relay as well
Quick Reply: engine shuts off
