993 Forum 1995-1998
Placement
Old Jan 23, 2010 | 12:38 PM
KBell's Avatar
KBell
Default Placement
Does the placement of these links look OK?
The bottom of the droplinks are a little bit forward. However, it is in perfect alignment with the Bilstein.
Or should I move the bottom of the link back one notch to make it verticle with the ground?
Kevin
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
Old Jan 23, 2010 | 01:15 PM
KBell's Avatar
KBell
After looking at the angle of the photo, the bottom looks really far forward.
In reality, they are in alignment with the bilstein.
Old Jan 23, 2010 | 01:17 PM
boulderbobo's Avatar
boulderbobo
Hi Kevin, it basically looks right. The drop link is installed parallel to the shock. The distance/clearance between your sway bar and lower control arm looks to be a little too much. That may because you are installing a different setup than mine (PSS10s). Here is a pic showing my install and the gap between the lower control arm and the rear sway bar and the install set up dimensions I used (courtesy ViperBob) .
Hope this helps
Bob-
File Type: jpg
File Type: jpg
Old Jan 23, 2010 | 03:13 PM
KBell's Avatar
KBell
The distance between the sway and the lower arm is alittle over 1"
Old Jan 23, 2010 | 03:25 PM
boulderbobo
Should be good to go
Old Jan 24, 2010 | 12:54 AM
VMXWinn's Avatar
VMXWinn
Kevin, It looks good. the shock pick-up point and the swaybar pick-up point should be in the same plane or aligned. Looks like you are running the H&R swaybar. Also I would add another threaded collar as a jam nut to locate the spring perch/swaybar mount.
Good luck with the new shocks
Darren
