993 Forum 1995-1998
Completely disabling an Immobilizer
Old 01-20-2010, 02:04 PM
Andre'
Andre''s Avatar
Thanks a lot for the update!
Regards, Andre'
Old 01-20-2010, 02:11 PM
David in LA
David in LA's Avatar
Do you have more info and pics of where the switch is located? Also since the entire car is powered down, does the ECU need to relearn it's setting once the battery is connected?
Originally Posted by tctung
My 993 is of Euro spec but this part might be the same. I had the shop install an OMP battery kill switch. (In Taiwan, parts and labor cost about US$100.) Every time I am done parking, I switch off the battery completely. When I need to use the car, I switch it back on. Although the immobilizer starts functioning right away, I can easily disable it by locking then unlocking the door with the car key.
Merits of doing the above are:
*You can park the car for 6 to 8 weeks and the battery will be still juicy.
*Except yourself with the key, nobody else can start the car because once the battery is switched back on the immobilizer will start functioning. (Thief would need a tow truck to steal your car.)
Old 01-20-2010, 02:16 PM
Mark in Baltimore
Mark in Baltimore's Avatar
Weird. In seven years of 993 ownership, I've never had an immobilizer issue.
I'm sure I just jinxed myself!
Old 01-20-2010, 02:28 PM
Edward
Addicted Specialist
Edward's Avatar
9 years for me
But then again, I have the superior '95 sans immobilamer and SAI. Lots can be said about keeping things simple
...sorry, guess that wasn't very productive. Carry on, gents.
Edward
Old 01-20-2010, 08:44 PM
tctung
tctung's Avatar
Sorry I am just a tourist here and cannot post pics. My mechanics installed the switch right on the cable that leads to the negative pole of the battery. He cut the cable then hand soldered the switch onto the loop. (Every time I need to open the front hood to switch it on or off.)
Since the whole car is powered off, the ECU may need to relearn its setting, I guess.
Old 01-21-2010, 04:44 AM
Steve Weiner-Rennsport Systems
RL Technical Advisor
Steve Weiner-Rennsport Systems's Avatar
Does the ECU need to relearn it's setting once the battery is connected?
Not unless the software was recently re-programmed.
Regardless, its a simple matter to do,......after reconnecting the battery, simply turn on the key for 2 minutes without starting and then proceed to fire it up and let idle for 2 minutes.
This also assures the MAF relearns its baseline settings.
Quick Reply: Completely disabling an Immobilizer
