Which gear at 30 mph?
There's a 3 mile stretch of road I drive everyday and the posted speed limit is 30 mph..
Should I drive it at 3000 rpm in second or 2000 rpm in third?
....Thanks...
....Thanks...
I don't think you can really "lug" a 911 engine. In the old days, with the 356 four cylinders they used roller bearings which when lugged could "flatten out". But as long as the engine is not bucking, you should be okay. Plus the modern fuel injection will prevent the plugs from getting fouled. But even so, if you habitually drive this way, you should run the car out on the highway for some sustained 3000 rpm work. Clears out all the cobwebs.
Gears I drive...
Easy to remember (use your ears & Tachometer):
0 to 20 mph = 1st gear,
25 to 30 mph = 2nd gear,
30 to 45 mph = 3rd gear,
45 to 55 mph = 4th gear,
60 to 70 mph = 5th gear,
70 + mph (freeway cruising speed) = 6th gear.
Downshift 2 gears when passing a vehicle briskly...
To ljugete ...me likey da breakdown !
Personally I think it would depend on my mood. If it was a 'quiet / subdued' kinda day I think I'd "be quiet" and putter along in 4th. - on the assumption that there's no traffic lights and I would just be lifting off the accelerator periodically to allow for traffic spacing.
However, if it was a Friday or a day where there's a hint of spring in the air - and I'd just come off a really crappy winter -- and now I'm driving along with, eeek!, the window down and my arm out the window ...hell, fellas, 2nd. to mostly 3rd. gear to, ahem, let others enjoy the bootiful sound of my air-cooled flat six.
But, hey, datz just me!
Gerry
Gerry
2000 rpms?
These cars are meant to be rev'd up, not lugged.
I only use 6th gear when I'm in triple digits and never in second gear while on city streets where the speed limit is 30-35.
I high rev'd a 73 911s its entire life and sold it with over 125,000 miles on it and it still had 85-90% compression on all six cylinders when the new owner bought it.
Ask an air cooled Porsche mechanic his opinion on rpms.
I guarantee they share the same view. Low rev driving will only have you shelling out $6-8k for a top end rebuild sooner than needed.
You are kidding right?
2000 rpms?
I only use 6th gear when I'm in triple digits and never in third gear while on city streets where the speed limit is 30-35.
2000 rpms?
And for those of us with tips, you have to drive in manual mode in order to stay in 2nd and 3rd throughout driving in town on 25-55 mph roads. Otherwise, you'll be lugging around in 4th before you leave your driveway.
