I recently moved to PA from another state. Now I'm in the process getting my cars transfered. I checked the DMV and found a document regarding widow tinting in PA - see attachment. One of the previous owners of my C4S has tinted the side and rear widows. Also the car is a 1997.
Can you give me some input if this will become a PIA?
Probably, but only when you get pulled over.
If you actually follow the letter of the law, 70% (same as NYS) light transmission is very light tint. Some say why bother tinting your windows at all.
Is PA inspection done by state facilities or private facilities?
If state, then may not be worth the hassel.
But personally, I won't have any of my cars any other way.
Hey more PA peeps! Inspection shouldn't be a problem but the pigs on the other hand may hassle you. If you get pulled over they may make you remove it then come back to prove it. It looks like you said just the rear sides and rear and not the door glass?
Thx for the input. So - inspection seems to be no issue. But may the cops will become one if I'll get pulled over ...
The door windows are tinted too. Here a picture which should give you an idea of the tinting.
