Anybody know the part number for the RS hood prop seat?
The little cup that the rid sits in when in use. I bought the hood prop setup from Sunset and didn't get the little piece on the bottom. I think it replaces one of the four nuts that holds the upper shock mounts in place. I called Sunset and Bob was unable to find the part number for it. Thanks for any guidance.
Seared
Bart,
I just checked the ROW PET - nothing.
It could be as simple as a heat exchanger hex barrel nut - instead of the standard top mount nut. The nut I mention may afford a small cavity that the RS rod seats in. Just a thought.
Here's a pic of the hardware that came with my Perfect Power bar a few years ago - the barrel nuts are clearly visible:
![](http://img.photobucket.com/albums/v452/aowalter/Porsche%20parts/Bar2.jpg)
Andreas
Andreas
That looks about right. You can see what I think is a real RS posted by Manila here: https://rennlist.com/forums/993-foru...-pieces-2.html
Technical Guru
Bart, are these the correct part numbers for the compelte hood support package (e.g all you need to install?):
Socket head nut 999.085.001.02
Retainer 999.507.372.07
Hood support 964.511.569.00
Rod support 964.511.551.00
Do I need any additional bolts or washers etc.?
Sunset does list the part given by Jason above as a exhaust nut. And it's in stock.
Viggo, I would have to double check, but that seems right. You have to rivet the bracket on, and they are not included.
