Weight Diff - Big Reds vs. Stock 993 ??
Does anyone have the data on the weights of the 993 C2 and Big Red, front and rear calipers and rotors???
Mytrack car has lost a lot of weight and I'm considering switching to stock brakes if the unsprung weight difference warrants it.
Jeff
Jeff
Calling Bill Verburg
But in the meantime, have a read from his page:
http://members.rennlist.com/1976c38/brakes.htm
rear is 5.2# heavier/wheel or 24.76% heavier
you don't change to these casually or for looks
It's the dry weight of the calipers and rotors, add a few pounds more for pads and fluid
Addicted Specialist
Wow. I figured they'd be a bit heavier, but that is quite a significant difference per wheel, especially given that this is unsprung weight! Thanks for posting that, Bill. Makes me feel even better about the "little blacks" over the "big reds"
Edward
You meant to say "the dry weight of the calipers and rotors," right?
Wow. I figured they'd be a bit heavier, but that is quite a significant difference per wheel, especially given that this is unsprung weight! Thanks for posting that, Bill. Makes me feel even better about the "little blacks" over the "big reds"![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
Edward
Edward
the front pads are just a little heavier, the rears a lot heavier, but I sold all my old pads so can't weigh any.
How much do you think unsprung weight can be detected in a street car driven on the track? I am considering lighter rotors which are much more expensive, and trying to figure out if they are worth it. I may do an A-B test, but I have to wait many months to find out. There may be a 3-5+ lb difference per rotor.
Davehy
Sorry - I actually already have a complete C2 set of brakes. A good friend was kind enough to wreck his 993 at the track this year so I got a set cheap.
Jeff
Jeff
Addicted Specialist
Edward
Are there any gains to changing to big reds from stock "black" on a standard C2 with no engine mods used 50/50 track/street?
I am guessing that the bigger brakes were meant to handle the extra power of the Turbo. Aren't the brakes matched to the car's weight and power... ? Please correct me if I am wrong.
I am a sponge! And a dry one at that :-)
993RS & 993tt used the same front calipers and same size(322x32) front rotors but RS were 1 piece and tt are 2 piece. everyone uses the 2 piece versions
993RS & tt rear calipers use the same pads(same as 993 front pads) and rotors(322x28) but have different piston sizes. RS has 30/36 tt has 28/28.
The RS has more rear bias that can be used on lowered track cars w/ stiff suspensions and effective lsds.
the point of the bigger brakes isn't so much stopping torque(though that is much better than stock) but to handle the heat generated during track use. The RS/tt brakes will last much longer than stockers because they run cooler, both in a given session and for total # of track days before replacement is necessary.
