Merry Christmas to me. Got a CEL from Santa..
I had similar codes and it was just a bad batch of fuel. The light went off when I turned on the key after getting the tank refilled. From this point, I will never get fuel from older stations again (even brand stations). If the tanks gets empty you suck in all the gunk that accumulates over the years and our cars are very sensitive.
+993. I never go to a station when it's being resupplied.
Could be a failing dual mass flywheel. Do a search as you will find some info out there on this as a possible cause. I kept getting random misfire codes even after doing plugs, caps, rotors, wires, etc. Changed out my DMF to a LWF and have not had another random misfire code since.
A bad stall really 'torques up' the two sections of the DMF , which briefly changes the apparent crank centerline wrt the TDC sensor in the bell housing .... telling the DME that firing did not occur at the correct time/position ....
The cure is quite simple!
New wires/caps/rotors sorted it all out for me.
Cleared the codes. Filled the tank and added Techron.
Drove for a bout an hour. Nothing so far..
FYI the car drives just fine. Nothing noticeable in terms of performance related to the CEL
![Smile](https://rennlist.com/forums/images/icons/icon7.gif)
...we saw on the Board a while back, that Otto's in Venice, and Hergesheimer's in Lake Forest have had success clearing the CEL code. Callas Rennsport in Torrance is another great shop.
