DDM HID Foglight upgrade - UPDATE, Fog Test..
The base should be the same. The offset pins are for dual filament bulbs, single filament are opposite pins not offset. The LED picture you posted looks like it has both types of bulbs (note the bottom contacts) but you can only see the pins on the double filament - or in that case technically double circuit LED. The one with the single bottom contact should fit.
Thanks, Jason ... I appreciate the kind words and all the great info you've provided to all of us this past year as well ....
The closest to 4300K that the DDM kit's offer is 4500K in an H3 bulb. I have a Retro-Solutions 55W H1 HID kit for low beam headlights and in the pictures you can see that the foglights illumination on the grass appears slightly bluer than the headlights alone, but when you look at the car straight on with both headlights and foglights on, they all look white for as long as you can stand to stare at them ...
Thanks for the tip, I'll check them out.
I will certainly be re-doing the kit's 'sticky pad' attachment scheme because removal of the housings at this point would be difficult without dislodging the ballast/ignitors from their perch. It would be great if you document your process/improvements for posterity ...
Somehow, I got my hand and a small rag with some cleaner on it back in there and got it scrubbed down. You only get one shot at nailing the position of the ballast, as the stuff sticks like gorilla cement ... good for one application, but not RnR.
Thanks JP...I keep looking at mine and thinking, whimpy lights!
I am thinking of getting the 35w from better bodies.com with the integrated air inlet. Anyone had any experience or feedback to offer on those?
Nice install write-up, thanks. Please report in when you get a chance to really use them in fog (real fog, not the heavy haze some call fog - you know what I mean I'm sure). My fear is they'll actually be too bright to be useful as fogs and around here fogs are a lot more useful than driving lights.
