Rear wishbone rose joint, where to get please!
Hi There
On the longer arm of the rear suspension wishbone ("V" arms) there is a solid bush which I would call a rose joint. Does anyone know a supplier of these?
On mine the joint is worn but the rest of the arm and ball joint is fine and I am changing the rubber bush on the other arm.
It seems like a real shame to junk the arm for the sake of the bush.
You can get refurbished ones (whole wishbones) so the part must be available. It will not be a Porsche part because they are certainly not available seperately.
Many thanks for any help
Berni
Berni
