993 Forum 1995-1998
identifying big reds ?
Old Dec 7, 2009 | 09:19 AM
jackal2513's Avatar
jackal2513
Default identifying big reds ?
guys, if you have in your hands a pair of big reds and a pair of big blacks (928 GTS caliupers) or 968 M030/944 turbo calipers (also known as 928 S4 calipers), question is how do you tell which is which if they are all painted red ?
the big blacks and the 944 turbo calipers are a trainling mount as opposed to the leading mount that the 993tt big reds are but how can you tell this ?
would apprecaite any input here
thanks
R
Old Dec 7, 2009 | 09:25 AM
J.A.W.S.'s Avatar
J.A.W.S.
big reds/blacks are notable bigger/wider then the others...
(big blacks in the middle, 968 M030/944 turbo (S) left)
Old Dec 7, 2009 | 09:28 AM
J.A.W.S.'s Avatar
J.A.W.S.
sideview big blacks:
compared to 968 M030/944 turbo (S):
Old Dec 7, 2009 | 09:33 AM
jackal2513's Avatar
jackal2513
thanks
are these big reds then:
Old Dec 7, 2009 | 09:39 AM
jackal2513's Avatar
jackal2513
the caliper expanding spring looks to be upside down as well
i thought it was supposed to be hinged at the lowermost connection point and tilt downwards when you remove/replace pads
Bill Verburg's Avatar
Bill Verburg
25 Year Member
Originally Posted by jackal2513
thanks
I would say not, true big reds have a square raised lump on the outer edge next to the throat
the shorter 993/928S4 has a dimple there
Old Dec 7, 2009 | 09:40 AM
jackal2513's Avatar
jackal2513
thanks very nuch geoffrey
can i just ask though... how do you know they are not big blacks, 928GTS which have been sprayed red ?
I guess it probably doesn't matter because they are teh same caliper any way
Old Dec 7, 2009 | 09:42 AM
J.A.W.S.'s Avatar
J.A.W.S.
they look like 951/968M030s to me...
Old Dec 7, 2009 | 09:43 AM
jackal2513's Avatar
jackal2513
thanks bil
thats weird, the only big reds i have ever handled had that as well:
but then these ones on ebay dont either:
http://cgi.ebay.com/ebaymotors/Porsc...Q5fAccessories
Old Dec 7, 2009 | 09:44 AM
jackal2513's Avatar
jackal2513
here are genuine 968M030/944t/928S4
they look more like that in red
and besides, somehow they just dont look big enough for big reds in those photos
Old Dec 7, 2009 | 09:47 AM
jackal2513's Avatar
jackal2513
also if you look at big reds, the raised cylindrical area just before you get to the bleed nipple. that is quite short and stubby
whereas on the M030, it appears longer in teh context of the whole caliper
I'm pretty certain those ones i posted are NOT BR
Old Dec 7, 2009 | 10:04 AM
Bill Verburg
25 Year Member
also used in leading configuration on the front of 993
they were used in trailing configuration on 944ts but are not the ones used on 944t though. The 944t used the smaller ones used on the f/r of 964 and the rear of 964/993. JAWS in post #2 has the small 944t calipers all the way to the left(they are also radial mounts not axial mounts as used on the 2 bigger calipers
Old Dec 7, 2009 | 10:10 AM
jackal2513's Avatar
jackal2513
bill youve confused me now
the black calipers i just posted dont look anything like stock 993 front calipers ???
Old Dec 7, 2009 | 11:02 AM
Bill Verburg
25 Year Member
These
are stock 993 or 928S4 front, maybe also 968cs but I'm not really familiar enough w/ 968 to say. The difference between 993 and 928S4 config is leading mount on 993 and trailing mount on 928S4.
they were also used on 944ts in trailing mount config but not on 944t.
944t used the smaller axial mount pictured on the right here, on the left is a big red(note the raised square lump next to the pad retaining clip), to mount a Big red on 964 or earlier cars a caliper adpater pictured to the far left is used.
Old Dec 7, 2009 | 03:13 PM
jackal2513's Avatar
jackal2513
does the larger piston have to be position after the smaller pistons (as the wheel rotates) ?
