PST 2 question
Hi,
I know I am in the 993 Forum (probably because I own one
) but I have a 964 related issue with my PST 2. I am successfully using the tester since 2 years now on my 993 Turbo but today I tried to use it on a 964 C4. The problem is I cannot access the ABS ECU, there is no connection. I know the Bosch hammer has a special menu for the bleeding of the complex AWD mechanism of the 964 but could it be the PST 2 cannot be used on the 964 ? I tried 2 different 964 C4s and had the same issue.
Many thanks
Alain (looking for a 964C4 as a winter driver)
![Cool](https://rennlist.com/forums/images/smilies/cool.gif)
Many thanks
This _should_ work, however if you have a 964 this is "old" style round connector, right? Your 993 was an ODBII car and you are therefore using a different cable from the PCMCIA card, correct?
-reiner
-reiner
Thanks Reiner ! Yes, I use an adapter cable from the round plug to the OBDII of the PST2. I can connect to the DME, the airbag controller, HVAC and alarm system. But not to the ABS......
Alain
Alain
Alain, I am guessing that there is something missing from this adapter. When I first put my PST2 together I had the standard Bosch KTS500 cable and I could only read the ECU. It would fail to recognize all other systems. When I finally go the proper cable, it could now see that my C4 had ABS/ABD etc etc.
I don't have any experience with 964's, but I would drop by a shop that has a setup that works and borrow their cable and see if it works with your unit. Then a few minutes with a multimeter and some pen and paper should give you the pinouts and what is missing from your setup. Good Luck!
-reiner
-reiner
Reiner,
that's what I'm thinking, the adapter ! What is strange, is that I can read every CU except the ABS one. On the 993 it works. Now as to find a friendly shop willing to leave me alone with the adapter..........that's the downside of doing repairs myself. You usually go to the shop only when you're stuck![nono](https://rennlist.com/forums/graemlins/nono.gif)
Alain
Alain
