Any idea how to open rear seatbelt cover?
Hi All,
Could not seem to find this info anywhere. I'm trying to pry open the receiver- end of the rear seatbelt cover (right part in the photo). This is the part that houses the red release button. I'm doing this as it seems the only way to replace the webbing cover (left part in the photo), which has split on mine. Removal should allow me to slide a new covering on, which I have. The web and metal fitting are too large to slide through otherwise.
There seems to be 2 (possible?) release tabs visible inside if you push the button in. I've tried to pry it with some force, but can tell it's going to destroy it if I try harder.
Wondering if anyone has any tips? I've attached a photo for reference.
Thanks for your help-
Geoff
Geoff
