I need help bleeding brakes .Iam using a power bleeder but when
I pump up the bottle the brake fluid is running out the brake
over flow line why?All my fluid is on the floor pleaes help thanks.
You're pressurizing the master cylinder and forcing the fluid out of the overflow. take a vise grip and clamp it off right behind the master cylinder reservoir (IIRC).
