my new nussbaum lift
I have had a similar lift for a few years now. Very sturdy and more secure (-looking) than some other scissor lift posted on this site as the base is wider. Only issue is getting to the oil reservoir drain bolt - need to position the car carefully to make sure the bolt and the drain protrudes out far enough or you will get oil all over the platform. It is a great buy for those of you into DIY.
Large filter replacement is not an issue - draining oil requires a little bit of thought into positioning of the vehicle.
I bought this through jmc 1800 328-2181 talk with Jan Fisher.... she will take care of you. They only have 5 more left i waited 8 months for this new shipment to come in.
can you describe the make and model of your lift? I've looked at about 14 different models on the Internet, and most of the mid-rise lifts look pretty spindly.
Gary
here is a youtube video of the one from Greg Smith,
http://www.youtube.com/watch?v=E-e0gbT-RF8
http://www.youtube.com/watch?v=6E6dI...eature=related
haven't looked at this thread for a while as my hard drive died!
It looks very much like the OP's lift. In UK it was branded as Hoffman's.
I haven't taken any pictures as my garage is a little messy!
Another happy own here
Just got the lift and thanks Dutchcrunch for all his tips and help along the way!
The lift is just AWESOME. Built like a tank. Great access to the undernealth of the car. Some pics
Uncrating
![Name: IMG_7880 (Large).JPG
Size: 113.0 KB](https://rennlist.com/forums/attachments/993-forum/420047d1266263056-my-new-nussbaum-lift-img_7880-large-.jpg)
The 318ti on the lift
![Name: IMG_7888 (Large).JPG
Size: 136.5 KB](https://rennlist.com/forums/attachments/993-forum/420048d1266263056-my-new-nussbaum-lift-img_7888-large-.jpg)
The 996 on the lift
![Name: IMG_7937 (Large).JPG
Size: 125.3 KB](https://rennlist.com/forums/attachments/993-forum/420049d1266263056-my-new-nussbaum-lift-img_7937-large-.jpg)
Still have ceiling room to spare
![Name: IMG_7938-clean (Large).JPG
Size: 97.1 KB](https://rennlist.com/forums/attachments/993-forum/420050d1266263056-my-new-nussbaum-lift-img_7938-clean-large-.jpg)
996 bottom all covered up
![Name: IMG_7939 (Large).JPG
Size: 112.1 KB](https://rennlist.com/forums/attachments/993-forum/420051d1266263056-my-new-nussbaum-lift-img_7939-large-.jpg)
Enough clearnace to drop the engine?
![Name: IMG_7940 (Large).JPG
Size: 136.0 KB](https://rennlist.com/forums/attachments/993-forum/420052d1266263112-my-new-nussbaum-lift-img_7940-large-.jpg)
![Name: IMG_7941-clean (Large).JPG
Size: 59.3 KB](https://rennlist.com/forums/attachments/993-forum/420053d1266263112-my-new-nussbaum-lift-img_7941-clean-large-.jpg)
![jumper](https://rennlist.com/forums/graemlins/jumper.gif)
Uncrating
The 996 on the lift
![Name: IMG_7942 (Large).JPG
Size: 86.3 KB](https://rennlist.com/forums/attachments/993-forum/420054d1266263112-my-new-nussbaum-lift-img_7942-large-.jpg)
Quality appears to be top notch and I really like the fact that the arms roll on a steel base plate unlike other scissors lifts.
What I don't like is having to drive onto it every time I park my car. Which brings me to that piece of plywood in the background with ribs attached to it; is that an owner-fabricated ramp used to drive up onto this lift?
I'm considering one of these due to its narrower width...
Hemi Roadrunner Lift
here is their site.
http://www.nussbaum-lifts.de/front_content.php?idcat=82
I am considering one too even if 2 posts are available and cheaper here but are made in China. These Nussbaums are german made.
its a very good lift. its way more beefier than the one posted from youtube. the hydraulic rams are 2x the size of the china copy. what they do not mention is the nussbaum has an emergency down release in case of hydraulic/motor/power loss. so you can get your car down safely which non of the other lift have. this is important as if your car is stuck up on a lift it will be a pain to get down without it. you just have to remove the cover off the control tower and push 2 buttons. i know there are cheaper lifts but you cannot appreciate this lift till you see it in person, its quality all the way around, my only gripe is i wish the manual was in english. if i had to do it agin i would bye it. remember there are many lifts but for my situation this is best, its portable although heavy, but i can position anywhere in the garage which is nice.
any other question i will be happy to answer.
Try about 2 posts up or...
Are those short ramps at the ends hard to drive up on?
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
The owner-frabricated ramp in the background has nothing to do with this lift as far as I can tell (dutchcrunch please correct me if I'm wrong). Driving up the built-in ramp (about 16" x 12") is super easy with some finesse. Also, driving over the lift every time when you park is a little inconvenient but it won't hurt the lift at all since when it's lowered, everything is folded up tightly against each other.
If I'm not mistaken, the Hemi lift is very similar to the very popular Bendpak MD-6XP. If so, you can't just drive over it. You have to build ramps around it.
Also, the Hemi lift has a footprint of 39" (wide). The Nussbaum is 69" wide. No comparison in terms of stability for sure. But of course the Hemi/Bandpak should cost a lot less though.
