The 993 re-gear challenge - The Street version
#61
Personally, I think the spacing is just awkward overall. It feels like Porsche just geared it for a specific efficiency/rpm to meet US requirements, but neglected the actual gear-gear spacing to a large degree as a result. I wish they had just made a close-ratio 5spd gearset and added a tall 6th for cruising/economy at speed.
Like most things in life, there isn't really a magic number that works for everyone since the use case and associated needs can vary. That said, if budget is unlimited and/or you're racing then fixing all 6 gears in some fashion makes sense. For a budget/street build, I still think the 3/4/5 change is the best value. Granted, I don't have this setup, but if/when the transaxle is rebuilt this would be the course I would take based on the data available.
#62
I probably posted this earlier in this thread but I have a regeared box with a lower 2nd (2.4) and 5th is in 6th. I like everything except I would like a taller top for the highway (0.857 instead of 0.921). Its just a street machine.
#63
+ 1
The biggest issue for me is the gear noise that will result after a re-gearing process. I have been told by the experts that all aftermarket gears will whine.
In my opinion, that is unacceptable for a street car.
#64
I'd have to look back to see who made the gears in mine but the only whine is decel in 2nd sometimes. Its really a non issue for me. There are way more compromises with a LWF.
#65
Mine is also regeared 2-6 and I added a proper LSD. Motorsports gears do whine but I don't find it intrusive at all although I did opt for the euro 6th which is a factory gear (no whine). Perfect since that's really the only one you'd notice it (long cruise). Big dollar mod yes but totally transformational in terms of real world drivability. Nice and tight down low (1-5) and a usable 6th.
#66
Holy thread resurrection! Perfect timing though, as I have been edumacating myself on this. Seems to me the G50/21 gearing would be pretty close to ideal for a mostly weekend street car. I wouldn't mind a even lower 2nd, but I can't get the rest to spread out nicely. Wonder if it is cheaper to just buy a new G50/21 instead getting it custom regeared...
#67
#68
#70
RL Technical Advisor
If one wants a totally silent transmission, one simply buys factory gears, however thats a VERY expensive proposition.
Everyone's ears are different and I always counsel anyone concerned about gear noise to take a ride in someone's car with Guard gears to hear this for themselves to see if this is really an issue or not. This is really FAR better than listening to opinions from experts or anyone else for that matter.
#71
#72
8th Gear
I have a 95 with an early G50/21, stock flywheel, 19" wheels, and street use only. My only complaint is the larger rpm drop between 1st, 2nd, and 3rd. My 1st gear feels like a granny gear even with the taller 19" wheels. I am tempted to try a G50/31 1st and 2nd in my 21.
I love the lower rpm drops between 3-4-5, what a pleasure to drive. My 6th gear is also ideal for cruising the freeways (.8205).
This is a great thread, interesting to hear other perspectives and ideas, thanks.
#73
Hasn't seen any re-gearing discussion for a while now. Let's beat this dead horse more ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Driving up a steep hill in SF the other day and smoked the crap out of the clutch. Who puts a stop sign at the top of a hill! Probably boiled the hydraulic fluid and it feels like there is air trapped in the clutch line again >![Frown](https://rennlist.com/forums/images/smilies/frown.gif)
Anyway, the point is that, I definitely do not want the taller first gear from the RS. With a car that see quite a bit of normal street driving, I think the first feels pretty nice. A factory G50/21 with LSD is about $10k (with core charge). A custom gear set is probably in the same ball park but there is the whine to deal with.
#74
I changed to RS ratios for 3, 4, and 5. Kept 1, 2, 6 stock. Absolutely fantastic gearbox. Really wouldn't want 5th gear in 6th position -- terrible for modern highway travel. And there is no discernible difference in 2nd gear ratio between the /20 (stock U.S.) and /31 (RS) boxes.
No-brainer, IMHO, to do it this way -- great bang for the buck.
#75
