What's on your winter to do list?
#33
To do list:
Plugs
Valve cover gaskets
Dist belts
fluids
RS door panels
RS radio delete
lower even further- corner balance yada yada
new rubber on all three sets of wheels
#35
Let me know when you're gonna do this Mark. I have one sitting in my workshop and would like to brainstorm on how to do the install and dash bracket.
To do list:
Plugs
Valve cover gaskets
Dist belts
fluids
RS door panels
RS radio delete
To do list:
Plugs
Valve cover gaskets
Dist belts
fluids
RS door panels
RS radio delete
#36
Dang, I also need an A/C compressor.
#38
Matt777, not sure if you have the same symptoms but my car was hanging up when I had to downshift while decelerating and had to blip the gas to disengage the clutch. Took it to the P-mechanic and he lowered the transmission and found corrosion in the input shaft. He lubed the shaft and now the gear box is as smooth as silk.
Thanks, Matt
#42
Cheers,
Paul.
#43
I will write a list, but I don't know how much of it I will actually get done.
-Replace Stereo/speakers
-Replace seats with lightweight ones
-Work on exhaust
-Heater duct bypass
-Short Shift kit
-the standard brake pads, rotors, spark plug, distributor cap, replacements
-Work on exhaust
-Heater duct bypass
-Short Shift kit
#44
